Pabstkiller
- Oct 20, 2021
- Rothschild Wisconsin
- 2006 apex
06 apex will run and idle awesome till you go to move then at 4000 rpm then it dies and flashes er-1 any idea we’re to start?
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
How many miles are on sled? Speedo bearing. Also theres a white plug next to fuses to the left of the battery unplug it see if its dirty/corrosion
Have you had it apart recently? Also check wires in nose by rectifier. First time out this season?
Take a look at the speed sensor under the secondary clutch. The speedo gear may be up against it.
Dave42
- Feb 5, 2022
- Minnesota
- Apex
Mine died on the trail yesterday, with these exact same symptoms will run but not go anywhere Err-1
Going to check the bearings.
Pabstkiller
- Oct 20, 2021
- 2006 apex
sleds got jut over 6600 on it. I took it apart last spring when I got it and I've but around 600 mile on it this season.How many miles are on sled? Speedo bearing. Also theres a white plug next to fuses to the left of the battery unplug it see if its dirty/corrosion
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Were you able to look at it at all?
Pabstkiller
- Oct 20, 2021
- 2006 apex
no not yet I wasn't able to get it home till last night ill be digging into it tonight after workWere you able to look at it at all?
