Pabstkiller
- Oct 20, 2021
- Rothschild Wisconsin
- 2006 apex
06 apex will run and idle awesome till you go to move then at 4000 rpm then it dies and flashes er-1 any idea we’re to start?
slowride06er
How many miles are on sled? Speedo bearing. Also theres a white plug next to fuses to the left of the battery unplug it see if its dirty/corrosion
Have you had it apart recently? Also check wires in nose by rectifier. First time out this season?
Take a look at the speed sensor under the secondary clutch. The speedo gear may be up against it.
Mine died on the trail yesterday, with these exact same symptoms will run but not go anywhere Err-1
Going to check the bearings.
Pabstkiller
- Oct 20, 2021
- 2006 apex
sleds got jut over 6600 on it. I took it apart last spring when I got it and I've but around 600 mile on it this season.How many miles are on sled? Speedo bearing. Also theres a white plug next to fuses to the left of the battery unplug it see if its dirty/corrosion
slowride06er
Were you able to look at it at all?
Pabstkiller
- Oct 20, 2021
- 2006 apex
no not yet I wasn't able to get it home till last night ill be digging into it tonight after workWere you able to look at it at all?
