I cant see what you can... pull the air box and battery cage and start looking... maybe a split oil line off the bottom of the motor that feeds the oil tank... if its pissing that much oil it should be easy to locate. Use brake clean to clean the mess if its all over...
smokingcrater
100% sure you hooked up all the hoses going to the air box? If you miss that little one on the bottom, your engine will puke out A LOT of oil, enough to empty the tank in 10 minutes or so...
kevin langford
- Dec 11, 2014
- 06 yamaha nytro
Its pretty dark outside now but im going for a look anyways ill be right back with more info
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Make sure that the infamous "small hose" is connected on BOTH ends. Underneath the airbox, RH rear corner (as you are sitting on the sled). Make triple sure that that hose is also connected to the fitting on the block.
As Mr Sled pointed out, the lower oil tank line that goes to the engine could have split but I can't recall ever hearing about that happening.
Oil filter split?
Where is the actual oil pump on these engines?
kevin langford
- Dec 11, 2014
- 06 yamaha nytro
hose under air box was not connected hahaha i feel stupid and no matter how many times i try to put it back on when i try to fit the air box back onto the carbs which it a complete bitch of a job the hose falls off again the hose is just way to short!
LMAO.... well see , next time double check
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Relax. Look where the hose goes down along the block and attaches to a nipple. Use a long needle nose to open the clip as well as removing the hose. From the top pull up on the hose until you have enough to easily attach it to the airbox. Then, take your needle nose and attach the hose to the block nipple. Don't forget the clip.
This does involve taking off the side panel but it makes the job so much easier.
kevin langford
- Dec 11, 2014
- 06 yamaha nytro
ok thanks for all the help! one more question do you think it will hurt if I put in royal purple 5w20 or castrol 10w30 in thats all I have on hand which would be the better choice? I would like to fire it up and see if that was the problem for sure
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
5-20
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
i wouldnt run anything but 0w in it but thats just me.
especially when its -40
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
He was just topping it off.........
J1635
Suspended
- Aug 17, 2014
- Yamaha Nytro
i know, i still wouldnt though. definitely dont mix synthetic with non either, dont know how much oil you lost but either way. id keep it all the sameHe was just topping it off.........
