motion
- Nov 9, 2009
i have an 07 apex that all of a sudden will crank but not fire, fuel pump is working and injectors are clicking when checked, just checked diagnostic codes and found while cranking code, ER-01 comes up, No ECU connection? Is this commen?
Len Todd
No, this is not common. Something has gottn disconnected. Did you recently do any work on it (e.g. like change the oil?) Check the ECU connection. Check the gage connection. Check the handle bar connections.Did you unplug any other connection?
Did you check all the fuses?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
what does ECU stand for?
Len Todd
Electronic Control Unit. It is the metal component typically located under the battery, or up in the nose of the sled, with all the wires plugged into it.
- Nov 1, 2009
- 2009 Phazer RTX
like a CDI unit?
Len Todd
An ECU is similar to CDI. But an ECU is much more complex than typically what a CDI unit handles. Everything that is electric is affected by the ECU. CDIs focus on ignition.
- Nov 1, 2009
- 2009 Phazer RTX
cool, thanks
