07 rtx inside ski lift
Mopar01
Winslow, Me.
Seems like I have played with everything and cant get a happy medium.
When I try lowering the front shocks down to about 45psi so they are pretty much level I get way too much push in the corners.
Front shock in skid is loose
Up one hole on limiter strap
2 lines showing on transfer rod.
added 1/4 shim to skis. I didnt notice any difference here.
Will adding the sway bar enable me to run lower pressure in the front shocks and keep me from pushing?
Buddies GT flat out corners...
If you dont have a 13mm sway bar that is what you need to get that will alone be the best upgrade for that sled. It will make a huge difference in handling but hurry snow is already almost gone!
Best upgrade you can do for inside lift.
