Hier_will
- Feb 17, 2020
- NH
- 2007 Venture Lite and 2009 Nytro XTX
I have a 2007 venture lite and have replaced last year, plugs, exhaust donuts and rebuilt both gearbox’s. The sled ran mint, but now it does not. Slightly hard to start need to give it a little throttle. The idle is set to 1700-1800 RPM. I gave it a little extra fuel in the CPU (5+) but still has a fluctuation at 20 mph, changes about 1000rpm while holding the throttle steady. Go to 30+ and it’s gone. Machine does feel like it’s running rough at any speed. It does have fresh 91 octane. Could this be clutch engagement or wiring and coils?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Check both plugs' condition (even new, they might give a clue). Check for a vacuum leak somewhere or loose throttle body. Then go into diagnostic mode and check that the throttle position sensor is working correctly and properly adjusted.
Hier_will
- Feb 17, 2020
- NH
I just checked the TPS and I’m getting zero resistance. There’s the culprit. Not a cheap fix.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Check to see if anyone is parting one out, either a VL, MP or Phazer. Also check with Barn of Parts.
So you checked it as per the manual?
