Sledder Joe
I found out how to get into the error codes but don't understand what all that means. I found a chart explaining what certain error codes mean but really don't get how to determine what is what. (It should be noted that while trying to start the sled the check engine icon and light flash) The oil filter was off for a few days while I was tracking down a seal that Yamaha only wants to sell with the cover in the picture but I am pumping oils back through the return line to the oil tank.
I'm pretty much stumped at this point any help would be greatly appreciated.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
what error codes are you getting?
crank position sensor will cause a symptom like this. have it right now on my phazer.
Sledder Joe
Not sure what section of the diagnostic area they are in.what error codes are you getting?
Sledder Joe
Where is it located? Not sure if I would have bumped it or something doing the work.crank position sensor will cause a symptom like this. have it right now on my phazer.
kinger
It cranks but wont fire? Crankshaft sensor I think is the same as the camshaft position sensor on the valve cover right above that cover you R&R'd. Check the plug is connected and tight. If you have a oil pressure problem the sled will start but it will shut off after 20 seconds. If it can't see the camshaft sensor it will not get spark.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
it will just show as a number on the display when engine light is on no need to go into diagnostics.Not sure what section of the diagnostic area they are in.
