motowrecker121
I'm working on an 08 nytro 121 for my friend. i have a couple questions. I'm installing the tracks usa 144 exstension kit with a 2" paddle track.
1 do i need to remove the tunnel protectors and the heat exchanger protectors?
2 do i need to go to an 8" driver?
thanks
thanks
thanks
#1 Yes and #2 no
motowrecker121
#1 Yes and #2 no
Thank you. any suggestions on gearing by going to the 2" track. also he bought the team TIAD clutch kit. so im sure ill be looking for some clutch tuning help too
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I run a 19 top tooth on my 2 inch lug , and a 20 top tooth and barn of parts soft start primary spring for 2800 rpm engagement on my 1.77 lug.
motowrecker121
Does anyone have an 08 service manual PDF file they could email to me? I can’t find one.
motowrecker121@hotmail.com
thanks
Ben
thanks
Ben
thanks
Ben
If you become a VIP I will send you one. It’s part of being a VIP as a perk.
motowrecker121
And how do I do that?
motowrecker121
I just sent payment
manual is otw motowrecker.
I sent it already.manual is otw motowrecker.
ok. he is double covered then.
motowrecker121
Thanks guys
motowrecker121
Does anyone know how many grams the clutch arms cams set up stock on an 08 nytro 121 set up for sea level
8GL00/10.3 outer & 17.2 center/inner should be about 61 Grams
motowrecker121
so I went to change the right front spindle on the sled because my buddy bent it. the new one from yamaha is different. the tie rod bolts in farther to the out side of the ski. was there an update on the spindles?
