snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I just got the sleds home from storage and all fired up but one, 08 nytro has a new battery and I got nothing. Pull up the kill switch turn the key and she is dead. What should I be looking for? any help would be great, Thanks
Way2fast
- Sep 11, 2011
- NY
- 2014 Apex XTX, 2009 FX Nytro RTX SE
Check the connector on the cable that goes to your key. It gets corroded and once loose it acts like the sled has no power at all...mine gave out last year on the trail - luckily I managed to isolate the problem by pressing the connectors together (hard) and turned the key and the gauge lit up.I just got the sleds home from storage and all fired up but one, 08 nytro has a new battery and I got nothing. Pull up the kill switch turn the key and she is dead. What should I be looking for? any help would be great, Thanks
Hope this helps -
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Is that a brand new battery as in this week, this year, this season?? If it's out of the box and fully charged you might want to inspect your cables for polarity. Check your main fuse in case you grounded out something on the batt install.I just got the sleds home from storage and all fired up but one, 08 nytro has a new battery and I got nothing. Pull up the kill switch turn the key and she is dead. What should I be looking for? any help would be great, Thanks
Matt_phazer_rtx
- Dec 10, 2009
- Riverview, Ontario
- 2009 phazer rtx- 1.75 b/c 7" sly dogs
2008 nytro rtx 40th- studded barker pipe
had same problem last year, figured out it was a cable under hood battery side up towards headlight
kept key on and messed with wires. seemed that wires going into connector werent in enough.
snopro442
- Dec 10, 2007
- neenah wi.
I checked the key switch wires and where they plug into the harness they are full of green mold looking stuff. Whats the best way to clean this out? Thanks
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Normally you can clean it with penetrating oil. If you have or can get battery terminal cleaner that will work also. Once clean apply a little anti corrosion grease. I prefer truck lite, NYK-77 compound. http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=23656
snopro442
- Dec 10, 2007
- neenah wi.
cleaned it, greased it and good to go!
