rkkoeb
So I am going to replace my track on my 09 apex plus bearings in chain case. I believe the large nut of the shaft in the chain case is a 36MM but what tool do I need for the nut behind the secondary clutch on the jack shaft? I heard there is a special tool you need to tight and remove this nut. Any help would be great
blown apex
i use a big crescent wrench(adjustable wrench) and pry bar in clutch to hold itSo I am going to replace my track on my 09 apex plus bearings in chain case. I believe the large nut of the shaft in the chain case is a 36MM but what tool do I need for the nut behind the secondary clutch on the jack shaft? I heard there is a special tool you need to tight and remove this nut. Any help would be great
rkkoeb
I am more concern about how to get the nut off of the clutch side
rkkoeb
This is the nut on the back side of the bearing on the split collar. I was told there is a special tool to tighten the slit collar with the nut
2016 apex xtx
never owned the tool myself. you are probably looking for a spanner wrench like the one for adjusting coilover shock springs. i tend to use a hammer and punch/chisel on my stuff and have not had one come loose yet.
rkkoeb
I think this is what people had talked about using before
Teamblue4
- Feb 20, 2008
- Il.
2012 Apex XTX
2013 Apex SE
2014 Apex SE
2016 Apex XTX
I used a spanner wrench.
rkkoeb
any other thoughts about that tool
Teamblue4
- Feb 20, 2008
- Il.
2012 Apex XTX
2013 Apex SE
2014 Apex SE
2016 Apex XTX
that tool pictured will not work, you cant get that tool over the jackshaft, use a spanner wrench, leave the secondary on and use that to turn and loosen nut, same with install.any other thoughts about that tool
