GetHighRacewear
SnowLurk said:You guys seem focused on bump settings, but where I ride its mostly smooth and fast. My goal is to set the Nytro to corner as hard as possible with minimal ski lift. Any advise on that? Thanks for the replies
I would let air out of your front fox floats(around 55psi with weight off the front end) take some rebound out(makes the shock extend slower) In the rear I would set your front shock with very light preload(maybe 1 or 2 threads showing on the shock body behind the locking nut) Set the torsion spring to its hardest setting. As far as the clickers, you are just gonna have to do trial and error. There really is no magic settings or numbers. The more you educate yourself/understand how the different adjustments work and react, the better you will be able to tune your suspension.
