linek800
Does anyone know who sells a aftermarket upper ball joint better then Yamaha's factory garbage. I have 2000 miles and both are shot. Call local dealer they what $152 a pop. WOW I think it maybe made of gold or something. Let me know what you guys are doing for a fix.
			MOUNTY
If ur ball joints are shot, ur bushings will definately be shot.  Check your spindles as well, ski hole mounts may be ovaled if bushings are shot.  Stock is NFG, no way the front end should need replacing after so little miles.  Installed a zbroz on mine because all teh parts I needed was more than the zbroz kit and if the bushings etc.. wear out in that little time Im sure they will replace with no charge.  Can. Warr. told me to pound sand.
mytro
linek800 said:Does anyone know who sells a aftermarket upper ball joint better then Yamaha's factory garbage. I have 2000 miles and both are shot. Call local dealer they what $152 a pop. WOW I think it maybe made of gold or something. Let me know what you guys are doing for a fix.
You can find factory Yamaha ones online for $60.00 each, and they ship to US and CA. Just do a search for Yamaha OEM parts, and get the lower balljoint kit from Arteeex they are great.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
 2009 Nytro XTX
MOUNTY said:If ur ball joints are shot, ur bushings will definately be shot. Check your spindles as well, ski hole mounts may be ovaled if bushings are shot. Stock is NFG, no way the front end should need replacing after so little miles. Installed a zbroz on mine because all teh parts I needed was more than the zbroz kit and if the bushings etc.. wear out in that little time Im sure they will replace with no charge. Can. Warr. told me to pound sand.
I just had lower ball joints and all bushings replaced on my YES warranty. Uppers were still in spec so they told me to bring it in just before my warranty expires and they would replace them.
linek800
mytro do you have a link for the ball joints. I searched the u.s and I found the best price was $100 from waldoch sports on mn. Thanks
			mytro
linek800 said:mytro do you have a link for the ball joints. I searched the u.s and I found the best price was $100 from waldoch sports on mn. Thanks
PM sent, Update profile so we know where you are located and what sled you have..
