nytro addict
sj said:but no header right?
Correct - I still have the stock header on.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
thats why nytro addict...no header...it seems like when you have the filter and header and exhaust..you get it..
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
The CO can be adjusted from the POD. I can't remeber the steps but there is a thread on it. You'll need to disconnect a wire or two in the front harness and press and hold buttons on the POD to activate the diagnoisis screen on the POD. Sorry I don't remember all the steps but search this site and there is step by step instructions.
http://www.ty4stroke.com/viewtopic.php?p=576397#576397
Kind of fuzzy print--but this works
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Thanks. Looks kind of complicated, but if it fixes the condition it will be worth it. 8
ericmichael
tcona-AGT said:http://www.ty4stroke.com/viewtopic.php?p=576397#576397
Do you need any extra wire to connect the two together or is it under the hood near the ecu?I'm going to try to richen it up alittle tomorrow.
you need a wire about 18"ericmichael said:tcona-AGT said:http://www.ty4stroke.com/viewtopic.php?p=576397#576397
Find the wire as described in "setting the co2 trim mode"A(It's under the coolant bottle.find the single white connector,remove black plug & insert wire & replace plug to hold it in place.Fasten wire to ground & follow steps---
I did mine last year(set to+10) & still have the wire in place for use if needed)
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Let us know if you see any results. You have more guts then me...that's for sure. Lol
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Any luck with the trim setting ericmichael?
ericmichael
eightpilot said:Any luck with the trim setting ericmichael?
Not yet! but I have tomorrow off..i'll let you know how i make out
ericmichael
tcona-AGT said:you need a wire about 18"ericmichael said:tcona-AGT said:http://www.ty4stroke.com/viewtopic.php?p=576397#576397
+10 did that correct the problem? How about the rest of the rpm range?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
each machine is different though....so one might need a plus 10 another a 20 etc
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
My sled today seemed to do more stumbling and hesitating as the engine warmed up. If that makes any sense, or it just might be me over thinking it.
twt1000
- Oct 25, 2009
I got my sled back from the dealer this weekend. They installed new crank sensor and rerouted the wires, adjusted the tps, none of this helped the hesitation. I did some adjusting on the co settings up to +15 on all cyls now and has not helped. Going on a week long trip next week looks like I am going to take it the way it is. On another note I was looking it over for my trip and found that all 4 balljoints are loose with only 611mi, I will be calling dealer on mon to let them know the hesitation is not fixed and all the ball joints are loose I hope yamaha will take care of this!
jipettersen
The hesitation is there from factory on every Nytros. They made it like this due to noise regulations !! i heard.
Put on a Rapid Bike III with proper map and its gone.
On mine i first installed the MCX turbo and the hesitation was more noticeable than before. I added on the RB3 and its gone.
