jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The fat lady called.. She said loosen that bitch up.
Jon i think the fat lady called and said dial that biatch in!
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Rednecks & DirtyHands running 1320'... always a fun guy to watch....and a reminder, to how much conditions play a role in your goal.
Fast
- Sep 25, 2018
Whats that dot way way behind them? looks like a polaris boostRednecks & DirtyHands running 1320'... always a fun guy to watch....and a reminder, to how much conditions play a role in your goal.
Has anyone seen or heard of any head to head competition between the Boost and Ski Doos 850R turbo?
Awesome! Thanks
GPS run in the Video:
Speedo indicating a max of 202KPH or 125.5 mph
GPS Max 176.3 kph or 109.6 mph
Typical Ski Doo Speedo...over indicating by 15%
I guess the positive for the Ski Doo guys is they finally have an 850 that will break 100mph
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I guess the positive for the Ski Doo guys is they finally have an 850 that will break 100mph![]()
The other videos I have seen have the boost leaving pretty badly on the doo but I think that is primarily setup at this point. With so little snow I don't think you will see any well setup comp-Rs until next season. Yes, the dream-o-meter is pretty bad on the doos.
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
114 in 500 ft
They’re getting faster
Haven't watched the video. They didn't use GPS to verify speeds?GPS run in the Video:
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
They do after awhile. 109 I think was peak.
We'll that's nothing to write home about.They do after awhile. 109 I think was peak.
Fleecer
- Jun 13, 2014
- 2019 SRX
I'm trying to compare those speeds to my winder. I'm not sure if 109mph is 1/3 throttle or 1/4 throttle. Can someone help?? LolWe'll that's nothing to write home about.
In our group not a single Gade Doo 850 will GPS over 100mph so at least the 850R can do it...sad indeed that it takes a meth injected Turbo on basically bare ice.We'll that's nothing to write home about.
That Doo dream meter is as bad as my Attak's speedo was before I took 2 teeth off of the sensor gear but at least my Attak would run about the same GPS speeds as the 850R Turbo without a Turbo!
- 11K
