can anyone tell me if the grizzly stator will hold up to 100watt off road lights or does anyone run them ..or just the 55 watt ones thanks for any info
660 SilverTip
- Jun 2, 2004
- Alberta Canada
- img78.photobucket.com
- Alberta Canada
- WLM
- tkoconsulting@telus.net
I haven't run into anyone that runs the 100w yet, but my dealer told me there is a separate coil winding for accessories which is kinda cool. PIAA makes a lite that is 55w but is way brighter. A few guys have said so. Part # ABA-70023-00-00
I would like to run another set of lights for plowing snow....I wonder how much to put on and where to hook in...hmmm
660 SilverTip
- Jun 2, 2004
- Alberta Canada
- Alberta Canada
- WLM
The PIAA lights listed above go in place of the factory headlamp bulbs. I'm sure The Speed Shop or Port Parts sell these. As far as aftermarket.....I'm guessing about 130-140 bucks for the pair and where is that aux lighting coil....not a clue. I was just told about it,not shown. I'll see if I can find out. Maybe someone here knows?
660 SilverTip
- Jun 2, 2004
- Alberta Canada
- Alberta Canada
- WLM
Check this out....several lights including PIAA bulbs.
http://www.portyamaha.com/catalog_items ... 54&Second=
Tan660
- Jun 8, 2004
100 watt lights
the 55 watt lights are your best bet i have 100 and cannot run them for extended periods of time or will drain battery.
iowagrizz660
- Jun 20, 2004
I run 55watt light in the winter when pushing snow on my Grizz. No probs!!
pfund28
- Jun 26, 2003
I added a set of 55w driving lights I found discounted at Wally world-boy did that brighten the world up!!!!! I tapped in behind the headlight and have them coming on with the brights
WoodyCam
- Oct 6, 2004
- 1 hr SE of St. Louis, MO
- www.winepress.us
- http://www.WinePress.US
So, these just take place of the original bulbs for my Yami Grizzly? Has anyone tried these? Are they high/low lights? I'm extremely unsatisfied with my stock headlights.
H6M 35W=55W Xtreme White Upgrade Bulb
ABA-70023-00-00 $28.95
Texas Grizz
- Aug 20, 2004
Just FYI, 55watts = 4.3 amps.
I think adding 2 / 100watts would stress the OEM charging system
I'm working on a HID conversion kit
pfund28
- Jun 26, 2003
Just buy a set of driving lights at kmart, walmart and tap into a hot wire.... I think I had $20 invested and they only come on with the brights...
Grizzhopper
- Jun 19, 2004
- Black Hills of Wyoming
- www.grizzhopper.com
- http://www.grizzhopper.com
- WLM
- grizzhopper
- YAHOO
- grizzhoppr
I would caution anyone with any ATV, NOT to use more than a single "pair" of 55 watt lights at any time.
110 watts of "additional" electrical load to the normal night riding load is running at the limit of practical risk.
Side Note #1:
Use of any winch "while" any ATV is running can result in an overloaded charging system under certain circumstances. I advise against it. Use the winch for a time, then start up and recharge for a timem. Cycle between winching and re-charging. I have seen expensive failures many times from this.
Side Note #2:
If you are one of the unfortunate souls who have purchased and installed the "ProCom Rectifier/Regulator" aftermarket module, don't even plan on using the OEM lighting without the risk of failure and a long walk.
Side Note #1:
Side Note #2:
Grizzhopper, I need to add some plowing lights for the Grizz, what do you recommend...I can see at night when the plow is up...the rubber flap is tall
Grizzhopper
- Jun 19, 2004
- WLM
- grizzhopper
- YAHOO
- grizzhoppr
I would install a set of "independantly controlled" lights (not over about 120 watts total). Off road or tractor lights are constructed a bit more durable.
Mount and wire them to the plow or its brackets, high up enough to be able to see. Then when you hook up to the plow, you can just plug in that dedicated set of lights and run WITHOUT the OEM lights. Since they are not doing any good with the plow on, why run them at all?
I would select a set of lights that have a replaceable halogen bulb. They are inexpensive and widely available.
The flood style light pattern would be better for this type of use than a spot or oval beam.
Awesome...great idea...thanks
