128" extension-need snowflap fix
BADSLED
Syracuse, NY
2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
For those of you who have extended your Apex to 128" what have you done to prevent your snowflap from getting sucked in by the track/studs? I bent out my aluminum supporting plate for the stock '06 flap as much as possible but wan't enough and it got chewed up. Now, I just completed installing a new style-rigid flap but can not bend back the aluminum support plate like with the old style flap. Otherwise, it sticks almost straight out.
Do I need to trim the aluminum support plate? I don't want to go to a shorter 12" flap as it appears not to kick up enough snow to the heat exchanger in low snow conditions..
