shadow44
I need a little help setting up my suspension up since I had the suspension relocate done. I'm getting a lot of transfer to the front when I let off the throttle. It's also extremely darty in hard pack. It's a 2008 RTX, front limiter is all the way out and not sure where the front skid shock is at. Any ideas or good starting points would be appreciated.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Shadow, did you have your shocks revalved for the 128" kit??? The stock shocks are too soft with the additional length..
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Put a little more preload in center shock. I went to a Hygear dual rate spring on the center shock after installing the 128"
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I did too...
