For those of you who have stretched out to 136 using the OFT extension kit. Have you been going through the hyfax faster or not?
When you place the OFT kit on, do you replace the hyfax with 136" ones or does the kit come with extensions to make up the difference?
I placed low snow wheels on my Nytro when I first got it and they fell off in the first 500 miles or so. This was after using locktite. Done with that.
Thanks!!
Thanks!!
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
if you look int the garage section You can see what I did, and revster also did for hyfax wear when stretched. needs an extra wheel towards the rear. I got 136 in hyfax and they are a bit short id buy 144 in and cut off what hangs off. the new dupont slides are 144 in, i think im going that route next time i need slides.
http://ty4stroke.com/viewtopic.php?t=102664
http://ty4stroke.com/viewtopic.php?t=88472
multi sled
raginyamaha said:if you look int the garage section You can see what I did, and revster also did for hyfax wear when stretched. needs an extra wheel towards the rear. I got 136 in hyfax and they are a bit short id buy 144 in and cut off what hangs off. the new dupont slides are 144 in, i think im going that route next time i need slides.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
multi sled said:raginyamaha said:if you look int the garage section You can see what I did, and revster also did for hyfax wear when stretched. needs an extra wheel towards the rear. I got 136 in hyfax and they are a bit short id buy 144 in and cut off what hangs off. the new dupont slides are 144 in, i think im going that route next time i need slides.
http://ty4stroke.com/viewtopic.php?t=88472![]()
x2 although the dupont sliders are too rich for my blood. I buy XTX sliders and cut them.Similar threads
