Is there any info if it is possible to install a 146" tack with 2.5/2.6" lugs together with 2.86 7 tooth drivers and offset rear axel with 9" rear wheel?
Or is set back of the skid, rail extensions og Iceage rail the only option? To my calculation I need to take up approx 46.4 mm or 1.83" going from 144" with 9 teeth 2.52 drive sprockets (183mm/7.219" diameter) to 146" with 7 teeth 2.86 drive sprockets (162mm/6.373" diameter)
I have googled and searched here on TY, but only information I can find with 146" track on a Nytro XTX is with a Ripsaw low lug track with 8 teeth drive sprockets
I already have the 2" 2.52 pitch track installed on my XTX, so looking for information if anybody have installed a 146" track with higher lugs than 2". I was looking into the composit talon M66 2 2ply track or the Camso peak 2.5". It would be a perfect match with mcx turbo without going all the way to 153" length track
