jjreds
- Feb 18, 2010
- Savona, NY
- 06 Apex RTX
15 Apex XTX
16 RS XTX
I've had this sled for a few years and it has always had a temperature related idle problem. When cold it will cycle from fast idle to a low idle about every 5 seconds. High-low-high-low etc. until it warms up. When the sled is warmed up it idles perfectly. However when cold when it drops the rpm's from fast idle down to a low idle sometimes it stumbles and stalls. Some signal that is controlling the idle speed is screwed up? I'm hoping a guru sees this and has seen this problem before, thanks
theCATman
What is/are you calling a low idle? 1550-ish is what they are supposed to idle at.
How many miles are on it?
Has it always done this, or something new?
Leakdown or compression test the engine.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Could be a tight exhaust valve lash situation like many of the 1049 SR Vipers suffered from.
CaptCaper
- Jan 1, 2007
- Northern N.H.
My 16 xtx vector always had a non smooth idle when cold right from the startup everytime. But when warmed up it runs like a beast. 4500 miles now on it. My wife has a 13 vector ltx and had a 2010 ltx which had a flawless cold idles. odd.
jjreds
- Feb 18, 2010
- Savona, NY
- 06 Apex RTX
15 Apex XTX
16 RS XTX
The idle speed changes fast for about 3 secs then slow for about 3 seconds alternating fast slow fast slow until it warms up. It doesn't maintain fast idle when cold. It's got low miles around 5K. I got it used. Always done it.What is/are you calling a low idle? 1550-ish is what they are supposed to idle at.
