jrice1987
all shocks are pretty well toast..... but rear is not rebuildable, what are my options I know kimpex makes one, 03 viper er shock? can I use the same spring from rx1 shock?
yes you can use the same spring on the kimpex shock. is the stock one aluminum bodied? i know the steel bodied ones are not rebuildable but the aluminum ones are.
jrice1987
can I use the kyb shock out of the 03 viper er?
yes you can. it is the same suspension.
jrice1987
Will the rx1 spring work with that?
yes.
- 7K
