Donald E Wiitala
Need seat upgrade for my rx1 03. I am to tall need seat for this next season. Can anyone help or suggest a product and contact info. I heard wrp is a good choice
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
in many cases just an 06 apex seat is enough for that sled I have a wrp seat on my apex and love it.
wrp is probably your best bet. brother has one on his 04 rx and prefered it to the apex gt seat he had before.
Donald E Wiitala
Whete do i get one?
Elton Buss
Travis at barnofparts sells them and he would also install the kit. I have one on my 07 attack, and I have an o6 vector mountain seat on my warrior. The wrp seat has the stiffest foam.
Donald E Wiitala
Just installed the wrp seat and it is real nice. Hight is good seat is comfortable. Not sure but i may need a bar riser.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Will the 2011 Apex seat foam and cover work on a 2003 RX1 seat frame? Just remove old foam and cover and install 2011 Apex foam and cover and staple? Seen it is possible, no mention of years, seems like the seat cover is the same 2006 to present.
Elton Buss
The seat pan is not the same because of the exup. You could alter the seat foam. But I still believe there is still quite a bit of difference in the trunk and exhaust area.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Thanks, forgot about Exup. There is a guy selling cover and foam on CL for 100.00, thought a good price vs buying WRPThe seat pan is not the same because of the exup. You could alter the seat foam. But I still believe there is still quite a bit of difference in the trunk and exhaust area.
