Dan50
- Nov 9, 2017
- Mukwonago, WI
- 2004 Yamaha RX Warrior
Hi guys newbie here. I've got the repair manual, but can't find anything on the easiest way to drain the tank. Do I need to remove it to accomplish this? If so any instructions please? I've searched and found a couple threads on different sleds, is it as easy as removing seat then disconnecting a couple bolts, etc.? Thanks!
Elton Buss
Yes it is that easy. Remove seat, disconnect fuel lines. It is easier to remove the handle bars,no need to disconnect any cables. you just need room too lift the tank shroud up so you can pull the tank out from under it. Remove the two bolts that hold the tank down. When you pull the tank out lift up the rear of the tank it is held in at the front by the frame loop.
Dan50
- Nov 9, 2017
- Mukwonago, WI
Thanks for the quick reply Elton. Wanna get some older gas outta there before I store it.
Elton Buss
You really only have to lift the rear of the sled up and sipone what you can out. There really isn't much left in after that.
After I sipone the gas out I just fill it with fresh stabilized gas.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Have you tried siphoning the gas?Hi guys newbie here. I've got the repair manual, but can't find anything on the easiest way to drain the tank. Do I need to remove it to accomplish this? If so any instructions please? I've searched and found a couple threads on different sleds, is it as easy as removing seat then disconnecting a couple bolts, etc.? Thanks!
I use a squeeze primer, for an outboard motor, to siphon gas from my sleds every spring. Once it's flowing good, it will take care of itself.
Elton Buss
I also run it to get the new gas through the system.
Elton Buss
Your cans fullHave you tried siphoning the gas?
Redbeard
- Oct 14, 2011
- IN
Sorry, Elton. I think we posted about the same time.
Elton Buss
No problem we all just try to help. Good luck with the crops this year.
Dan50
- Nov 9, 2017
- Mukwonago, WI
Thank you gentlemen,
I do have a siphon and hose. I will give that a shot first, should be able to get most of it out that way.
Al Bundy
What the heck is that puddle under the gas canHave you tried siphoning the gas?
Redbeard
- Oct 14, 2011
- IN
I'm getting old!What the heck is that puddle under the gas can
Redbeard
- Oct 14, 2011
- IN
Dan, fasten a rod to the hose so you can keep the suction end right in the bottom/corner of the tank.Thank you gentlemen,
- 46K
