cobalt650
Hello,
We are the original owners of a 2005 RS Vector. It has lead a very gentle life, mom/Grandma driven 3,500 miles. This year, upon changing the oil, I noticed that the rear end is sagging to the bottom. Lift it up, drop right down. A springs or shock issue? Thanks in advance!
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Stupid question but it's not on a dolly is it?
sounds like the shocks need to be serviced.
cobalt650
No dolly, on wheel casters. Feels like the springs or shock are kaput.
brothers was doing the same and perked right back up when we had the shocks serviced.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If the skis and/or track is up off the ground with wheels/dollies this will happen.
The rear shock on a '05 Vec with a Pro-Active rear suspension is not serviceable. Look for the rear shock out of an RS Nytro or 07-09 Apex RTX if you want something you can re-build/re-valve.
cobalt650
We've always kept our sleds with a wheel dolly under each ski, and one under the track. Is this s foul?
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Not foul at all. Just leads to the rear skid playing tricks on you until the sled is back on the level. Take it off the dollies and I bet your rear end reacts the way you expect it to.
