tedgoesfast
got some set up time with my new team tied secondary on sat.need to up my shift curve 200 rpm and its a bit lazy.So my question is were do i lighten the weight to up rpm all the way threw i was thinking of taking 2 grams of the tip by grinding what do you clutch guys think
grader
one gram off the tip should give you 200 rpm, start there. what spring are you using in the primary, and what is your max rpm at wide open? a higher rate spring like an orange-silver-orange will raise rpm through the shift curve, your max rpm should be 10500-10700. if your rpm is there now, just change the spring and dont touch the weights.
tedgoesfast
rx 1 weights
team supplied a new spring 77-260 lbs starts at 9800 and ends up at 10200 want it to swep 10200 to 10400.had a dalton set up in but could not get it to sweep the way i wanted it to.but the dalton set up was way quicker on bottom i will get this set up to go with more time
grader
the o-s-o spring is 35kg-143kg so the final number is higher (2.2x143). i run the 62 gram daltons dpyr till this year when i went to 144, but dropped back to the 58 gram set up to get rpm back. these weights work well and can be adjusted as needed.
