Sudburysledguy
- Jan 20, 2022
- Sudbury ,Ontario
- 2005 Yamaha venture rs
Replaced the fuse for headlights and visor …my visor works again but now only my high beams work ???
checked the bulbs? checked for power at the bulbs on low beam?
Sudburysledguy
- Jan 20, 2022
- Sudbury ,Ontario
No not yet I’m gonna be screwing with it tomorrow is it common to blow something else at the same time as the fuse? .. and is my visor wire supposed to be on the same one ? Cause as soon as I plugged my helmet in I seen the red light then boom the fuse blew
depends how and where the sheild is wired. i usually ran it to the battery on a separate fuse on sleds that where not equipped with one. if you are using rocks power supply, the 1st version came off of the high beam. the second came off of the power supply wire to the dimmer switch. you could have a dirty contact for the dimmer switch or burnt bulbs as i have seen them go when they get a power spike.
