Team Apex
Had my 2006 ER out on the weekend, when I started it it did want to idel at a constent RPM. it kept going up and down. when driving it runs great at higher speeds(over 6000 rpm) when you runnin under the 5500 rpm mark it starts to run rough missing and studdering> Give it gas and it goes great. with no problems. I changed the plugs and the gas in a heated garage and it then worked good for 30km then started to act up again. think it might have something to do with something freezing up or moisture problems. No fault codes, i did have the engine light flash at one point in time and the yellow light. Once I shut it off and re started it this went away and has not done it since. Any ideas???
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Donuts, and check your air box
