Cramleon
I have old seat cover removed up to the tool box , how do I undo it from inside the toolbox area?
Cramleon
Has someone on here replaced thier seat cover? If so how?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Inside the truck there should be a plastic edge where the vinyl ends, they are stapled to the plastic seat mould, just pry it off and the seat cover will come out.
Also do you remove the straps that go from the top of the seat cover to under the seat pan, there should be two of them.
Cramleon
Ok I will have a look. thanks
WinderFab
- Mar 1, 2009
- Woodbridge, ON
No problem..
The straps hold the seat cover where the lip is just before the trunk, the straps are attached to the cover and go through the foam and attached the the seat pan.
Cramleon
My factory seat cover did't have the two straps that go through the foam . But the new one does.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
My video may not apply, but the old seat I saw taken apart was no different than my 2012. They had no staples in the trunk, as you can't get in there to do it. It did have a couple straps inside the seat, as there is a bigger bump on the 2011+ seats. But there should be straps in the trunk instead of staples.
Good luck!
Good luck!
