Ehrenburg
- Jan 16, 2012
2nd time out on my sled this year (shortage of snow) and my sled is really hard starting, needs full throttle and full choke. Once i finally get it running, it is bogging and sputtering when i give it more than half throttle. Does this just sound like a carb cleaning issue? Im a carpenter - not very mechanically inclined. I should mention that it is also a turbo, would this cause any issue?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
might want to try posting this in the RS forum. but i think u need ur carbs cleaned. Had to do mine every year when i had a rage (same engine)
Did it back fire at all starting? I had that and fouled a plug
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Old gas, change spark plugs, and clean carbs.
Are you sure it's a Yamaha?
