Philip Morneault
So I managed to put on about 400 miles on my new to me Rage before the season was over for me and I want to get working on fixing/changing things during mud/bug season but I have a few questions:
First the steering, the handlebars are turned to the right to go straight and there is slop in them.
It appears where this needs to be adjusted is a link rod off of the steering post behind the engine, no room to loosen the lock nuts and adjust the length from the front, do I need to take the gas tank off to do this? If so, I cannot turn the screws that go into the aluminum tubing and hold the gas tank cover on, the screws are stripping, how do people handle that?
Second is the slop, there is a bit in one of the ball joints but most appears to be in the connections to the pivot arms, looks like there are bushings and collars in them from the parts diagram, is that what is worn out? Looks like a PIA to get at is there an easier way?
Last is where to power a 12vDC aux port so it turns on/off with the key/engine. Is there an accessory wire that can be used for this? I see a couple of wire plugs not used coming out under by the gas tank in the front.
Thanks!
~ Phil
Thanks!
~ Phil
why not get one of rocks toyz power supply? has 2 rca plugs on it and 2 usb ports for charging stuff and running heated sheilds. comes with instructions on where to install on the sled.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
There is 12v accessory plug in main harness by the fuel level sensor. Can get you details when back from my trip
Philip Morneault
Hi thanks, Ive looked at the wiring diagram and see that they are calling jack 43 the AUX port, its wires are o/b and black, Ill look at that area to see if there is a connector there with those colors.There is 12v accessory plug in main harness by the fuel level sensor. Can get you details when back from my trip
~ Phil
Philip Morneault
Hi so I haven't heard of this, I googled it and I do not find anything that looks like its for a snowmobile, can you share a link?why not get one of rocks toyz power supply? has 2 rca plugs on it and 2 usb ports for charging stuff and running heated sheilds. comes with instructions on where to install on the sled.
trail traveler
- Dec 3, 2014
- Everett, WA
- 2015 sr viper s-tx-dx
2014 Venture MP
2016 RS Venture
2017 sr viper x-tx
3- 1990's era Arctic Cat prowlers
Here is the link to Rocks site. http://www.yamaheater.com/
Philip Morneault
Hi thanks, not really what Im looking for, I have a yami 12VDC port, I just need to know where to wire it into the harness so it comes on with the key.Here is the link to Rocks site. http://www.yamaheater.com/
~ Phil
scroll down on the yamaheater products page to the smart supply. it is plug and play/
- 11K
