keith03054
I have 500 enjoyable mile on the new ride, and was hoping someone had info and maybe pics on the process to change the oil.
Also what type of oil, (brand, weight) and how much do I need.
Thanks,
Thanks,
Canadian Lad
I just had mine done today also. They put in YL4 0W30 and witht he filter it took 3 litres. also change the oil filter
keith03054
Did you see them do the work, I know you need to take the air box out, but what else needs to be removed (belly pan, etc.) to drain the oil.
Do you start out with the sled on it's side then lower it back on the skis once you are ready to drain the oil? I have the black GT also.
MadMax
I have a 05 vector........... Didn't need to remove the airbox??????????????????? Start by warming the motor.. Remove the right side panel..Remove the panel under the sled. Remove the drain plugs. (2).... Remove the oil filter.. It will be tight!!!!!!!!!!!! Watch for the "O" ring, it might be left behind.. Put everything back together.. Start out by putting two liters of oil in the tank.. Start the machine.. Let it run for a minute or so.. Stop and add one more full liter.. Do "NOT" add oil to the valve cover hole.. Not needed... It takes three full liters.. Check for leaks.......... Good to go.. Good luck.
MM.
MM.Vector ER
- Mar 12, 2004
- Ironwood, Michigan
- www.daveysmotel.com
Remember to drain the motor there is a drain plug next to the filter on the clutch side. Sam
MadMax
Vector ER said:Remember to drain the motor there is a drain plug next to the filter on the clutch side. Sam
That's why I put "2" drain plugs.
MM.A technician at the dealer said he always pour several onces of oil by the valve cover hole as well before starting..... so i did on my last oil change.
06vectorgt
Made the mistake of bringing mine to the dealer and got "Boned" for $180.00 for the 500 mile service.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Yeah thats a bit much. A dealer in hancock did mine for around $90 last year.
keith03054
Thank you for all the information, I want to do more servicing of the sled myself. Bringing it to the dealer takes more time, hassle and money to get these things done. With the support of this awesome site I know I will be able to accomplish that.
Thank again.
Thank again.
x2thez
- Mar 29, 2005
- Buffalo, NY
- 2014 Yamaha Viper LTX
2009 Yamaha Vector LTX
1987 Yamaha Bravo
The directions above are right on, I just followed the manual and it worked out great. The drain on the bottom of the engine has a little triangle next to it.
berge75
Theres also a screen,on the pick up line, in the oil tank that can be cleaned,but not nessary the first time around.
