sounding like there is a pin walking out in one of the connectors or corroded. had a weird starting issue one time on a phazer that this was the problem.
Could be those grounding blocks that you will find when you follow the wiring harness starting at the bottom of the steering post. I found a total of 5 square blocks and two flat blocks in my harness on my 08 Apex GT LTX. With my snowmobiles always being stored in my attached garage, those blocks were surprisingly in very good shape with no signs of corrosion or being burnt. I ended up packing the blocks with dielectric grease and retaping with electrical tape but do know they have been the root cause of many electrical gremlins where others have completely replaced blocks and soldered wires together.
