stacey mcclanahan
I need to replace my rear shock is there any aftermarket shocks I can use or any compatible to the original. To order one it has to come from Japan and could take months to get. Thank you
call travis at barn of parts. he most likely has a take off. as far as i know all the 4 stroke phazers other than the rtx use the same rear shocks. yours nor serviceable/rebuildable?
stacey mcclanahan
Thanks for the info, I don’t know if it’s rebuildable. I will try him to see if he has anything that will workcall travis at barn of parts. he most likely has a take off. as far as i know all the 4 stroke phazers other than the rtx use the same rear shocks. yours nor serviceable/rebuildable?
if the shock body is aluminum, it is rebuildable.
