BIG BLACK WARRIOR
Does anyone know what holes the spring on the driven clutch go into in stock setup. I blew the belt last saturday, and had to take the driven clutch apart to get all the cords from the belt that got wrapped around the clutch. When I took the clutch apart the spring flew out of the helix and clutch sheave before I could see what holes the spring was in. I put it back together OK on the trail, but seems to respond a little different when I give it gas. Thanks for any information.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Stock setting is 60 degrees, which if I'm not mistaken, means sticking the spring in holes 0 and 6.
60 degrees is 3-3
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
