goto802
Need assistance..09 carbureted..will crank no spark.new oem stator and crank sensor...power through ignition fuse and power to coils...chassis and engine grounds good
Something not plugged in correctly? follow stator wires to the nose cone.Need assistance..09 carbureted..will crank no spark.new oem stator and crank sensor...power through ignition fuse and power to coils...chassis and engine grounds good
goto802
All good two connectors...pretty positive engagement...anybody have pin voltage information
If you become a VIP I can send a PDF Manual. But here is a few screen shots of the electrical specs:
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Check all the wire splice blocks. They look like connector blocks with all the same colored wires coming in from one side. I've seen the ground splices fail on the carb'd sleds.
goto802
goto802
Cchecked ground block down near igniter.. very good ..chassis has good ground as well as engine.. i have power to coil positive but no pulse from igniter. Is there another ground block Im missing?
Chris Hammer
- Dec 26, 2020
- Sydenham
- Rx Warrior 1000 cc LE 2004
Hi goto802, where is your crank sensor on your motor? Do you have a 900cc engine or the 1000cc one?Need assistance..09 carbureted..will crank no spark.new oem stator and crank sensor...power through ignition fuse and power to coils...chassis and engine grounds good
goto802
Sorry it's an 07 893Hi goto802, where is your crank sensor on your motor? Do you have a 900cc engine or the 1000cc one?
goto802
Crank sensor inside flywheel ..replaced with oem stator assySorry it's an 07 893
goto802
Hey Grizz im back with crank no start 07 venture -- sled is totally grounded...three ground blocks i can find and ground at battery and module in nose good 15 amp fuse at solenoid goodCheck all the wire splice blocks. They look like connector blocks with all the same colored wires coming in from one side. I've seen the ground splices fail on the carb'd sleds.
RobX-1
- Coldwater, OH
Although my Apex LTX is a year newer, I found a total of 6 square grounding blocks and two flat grounding blocks. Of those square blocks, two are the ones above the primary clutch but there are three more further down the wire harness that goes into the nose and near the ECU. There was also one on the passenger side near the fuse box. On my Apex, there was also a flat ground block with the two blocks above the primary and another one with the three further down in the nose.
Check this post for pics of my ground blocks.
EDIT: Sorry, just re-read your post where you are now working on a 07 Venture and not an Apex. Still might be worth confirming you don't have additional ground blocks on that Venture than the 3 you found.
goto802
For sure...shouldn't be too hard to inspect for more blocks
goto802
View attachment 164195View attachment 164194View attachment 164193
goto802
Vip now...would love a manual
