Horizonls
- Mar 18, 2007
- Ottawa, Ontario
- 2011 Yamaha Apex Se
2007 Yamaha Phazer (Wifes )
2015 Yamaha Viper LTX SE (Current Ride )
My 2007 Phazer Gt will not stay running , while riding this weekend is was boggy for the first 30 minutes then died on the trail.
I brought it home and after it cooled down it fired right back and then died 3 minutes later, and then will not start until it cools down again.
Any ideas?
Any ideas?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Fouled plugs? Bad gas? throttle position sensor? Any flashing lights or codes?
Horizonls
- Mar 18, 2007
- Ottawa, Ontario
No it does not show any codes and seems to only die after it is warmed up, then will not restart. Let it sit for 6 hours and it fires right up.Fouled plugs? Bad gas? throttle position sensor? Any flashing lights or codes?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Someone in the VL/MP section is having a similar issue.
https://ty4stroke.com/threads/venture-lite-stalls-at-idle.152391
ground blocks good?
after that i would go after coils, cdi or stator as those can change in resistance value when heated or cooled. check with ohm meter 1st before changing parts unless you have a buddy with the same sled willing to let you test with his parts for the problem.
Horizonls
- Mar 18, 2007
- Ottawa, Ontario
I thought I will try it one last time, and it stalled twice but I was able to get it to run without shutting down for 5-7 minutes. Weird could be some water in the injectors .
throw a can of sea foam in the fuel tank and let it sit for a few hours before you try it again. lets the sea foam crawl up the lines to get rid of the water.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Hot running issue could be a bad coil, and with 1 cylinder dead it’s very hard to keep running or restart it. Weak coils usually spark ok when cold and loose strength as they warm up. Could also be a failing fuel pump.
Horizonls
- Mar 18, 2007
- Ottawa, Ontario
I added some Yamaha fuel stabilizer and it seems to have fixed the issue, it will stay running so far.
might have been water or crud in the injectors then.
