quadtrac
I have a 2008 nytro mtx, and want to make the tunnel look more like the 2010's. I seen that hartman inc, skinz, and van amburg all make a custom tunnel extension. Does anyone have some advice on which kit is the best? Thanks
outofbounds
- Feb 19, 2009
- Leavenworth and Bellevue Washington
I looked at Tom Hartman's solution - it takes a lot of work and some fabrication to complete this modification. So, it will cost more than the $200 for the hardware.
After looking around I went with Skinz. I was getting a Mountain Tamer rear suspension installed at a shop and had them add the Skinz mod.
The work is done - it looks great and seems to be exactly what I was hoping for. However, there isn't enough snow in my area to give it a good first try.
You should be able to install this yourself. The instructions are pretty straight forward.
outofbounds
- Feb 19, 2009
doo_man
