Winwinofsky
Hoping someone can help me. Have mcxpress on my nitro. Fuel pump heats up and shuts sled down. After packing snow on it and waiting it will fire up.
Is location of pump critical.
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I have my pump on the side of the battery on the mpi setup
Winwinofsky
Thx. That’s where mine was as well. I heard that it needed to be below the fuel level. Problem starts when fuel level gets low and idling or moving slow.
Winwinofsky
The pump gets hot. Have to pack snow around it and let it cool down. Then it runs ok. Until the next time.
Winwinofsky
I see on yours you have the fuel line covered on the one side. Reason?
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I think I had covered it for wear(rubbing) and maybe heat from engine. I have never had this trouble on a low tank that you are describing. I imagine the pump is cheap? I think I would go to the auto store and try a new one?
Winwinofsky
what kind pump are you running?Pressure? Thx
Winwinofsky
I’ve gone through three new pumps. Lowered pump. Will see how it performs. Thx again.
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
3 Ouch... I'm not sure the pump off hand. Pressure is 45-47
Winwinofsky
Mad pumps are around 70. Wonder if it’s too much
Winwinofsky
Mad pump is 70 plus
Winwinofsky
Msd
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
Interesting, not sure on that myself. Hopefully some other guys can give input on that.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I find External pumps do not last. I had a msd pump and it did not make it 2 months. I have switched over to a wallbro 255 pump and it usually lasts about 2 years now then starts making lots of noise and acting funny. So I switch it out. I also have my pump mounted at the battery location
Winwinofsky
if I could get two years out of it I’d be happy. I had mine mounted same place. Have lowered It to bottom of the battery. Some say it needs to be below fuel level? Also read that in front of steering rack where it will get cooler air.
