Mattcull
- Aug 27, 2020
- New liskeard
- 2009 Yamaha venture lite
I think my ecu is fried. Any help...
I was wondering if i can test it somehow?
I don't know of anyone with an ecu to switch with.
I have engine code 43 right now
last week engine code 81 came up. but only after the hand warmers were on for a period of time.
So now i turn the key and nothing happens. I hear a ticking sound from the buzzer and that's it.
So...I'm thinking ecu is done. Where's the best spot to buy one? Can I test it to make sure its busted. I looked for any wires that were creating a short or such thing, no luck.
try using a boost pack on it. sounding like a bad/dead battery atm. also sounding like the ground blocks need attention and that can cause some code issues.
Mattcull
- Aug 27, 2020
- New liskeard
k will def try the battery boost thing. I did check the ground blocks. I found two of them, both looked to be in good shape. is there more?
this thread has some good tips/info.
https://ty4stroke.com/threads/phazer-weirdness-likely-ground-block-issue.162412/
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Mattcull
- Aug 27, 2020
- New liskeard
Well I did get it started with the booster! So that’s good news. I recently replaced the stator - and for 14.7v as the output. I’ll check again. I wonder if the battery is just toast?Like @maim , I'm also thinking it's a ground or power issue. Check the things mentioned in that other thread. If you can get it started with a booster or after charging, check your voltage for proper stator output (~14v)
it will take a charge but perhaps isn’t holding it well? Man this electrical stuff is a pain.
Thanks for all the help guys! I really appreciate it!
Mattcull
- Aug 27, 2020
- New liskeard
I checked the voltage at the battery when running ... it’s 14.3vWell I did get it started with the booster! So that’s good news. I recently replaced the stator - and for 14.7v as the output. I’ll check again. I wonder if the battery is just toast?
but then why does the battery die? Batteries sure are a mystery . Guess it’s time for a new one
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
If it's original, I'd just replace it. Probably got damaged getting run down from the bad stator. At least you know it's working fine now.
x2 on what mooseman said.
