Mattcull
- Aug 27, 2020
- New liskeard
- 2009 Yamaha venture lite
I’m in the middle of trying to improve my reverse issues. It has a hard time engaging. I noticed my belt is riding to low in the secondary. How do I adjust? Everyone keeps talking about three bolts at the back. But my 2009 venture lite does not have three bolts, it has 3 screws. Do I separate the two halves and take out spacers??
Secondly, how do I adjust idle speed?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
A lot of questions are answered in the FAQ:
https://ty4stroke.com/threads/venture-lite-multipurpose-frequently-asked-questions.112343/
This one for the Secondary Clutch;
https://ty4stroke.com/threads/how-to-reassemble-the-secondary-clutch.101471/
Mattcull
- Aug 27, 2020
- New liskeard
i looked all through there, nothing about the spacers
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
The spacers are between the clutch halves.
Did you check your belt for wear? Usually when it gets low like that, it's time to change it. And oddly enough, when it is low like that, reverse usually engages easier.
Mattcull
- Aug 27, 2020
- New liskeard
the pics for the secondary clutch are gone.
there isn't much info on all this hey?
Mattcull
- Aug 27, 2020
- New liskeard
Its a new belt, maybe 100km on it.
but should i take a spacer out? will that make reverse harder to engage?
Mattcull
- Aug 27, 2020
- New liskeard
By low, i mean its flush with the top of the sheave (maybe a hair below the top. should I bother taking a spacer out?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Did you have a look at the reverse update bulletin for 07-08? Explains how to troubleshoot reverse issues and also has an image of the clutch shims. Yours being an 09 should have the extra shim. The idea was to lower the belt a little to lower tension on the reverse gear. It didn't help me much and oddly enough, the original -00 belt worked a little better than the -10 for me.
Mattcull
- Aug 27, 2020
- New liskeard
K Thank you!
I just took it for a spin and it seems to be switching great!!
Thank you for the help!
