Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Any thing I should know before tackling this job? I have ordered and revived the new rivets, heat exchangers... I have an electric rivet gun for re installation. I searched for link with none found.
Thanks Terry
Thanks Terry
Not understanding "Rear Foot Exchanger"
I use a vise grip with smooth flat jaws. This blocks the coolant from completely draining from the system. Punch out the metal pin from the rivets and then drill them out.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Search for the following post by Redbeard he shows changing one on a warrior(same tunnel design)not sure about an electric riveter? Most use air powered you might want to test a rivet first as the double grip rivets are fairly hard to driveAny thing I should know before tackling this job? I have ordered and revived the new rivets, heat exchangers... I have an electric rivet gun for re installation. I searched for link with none found.
Thanks Terry
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Thanks Guys for the info.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
All back together and no leaks! Not as bad as i thought! nothing like an air riveter to get the job done !
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
So here are some pics of the old coolers. Cracks are were the suspension mounts to running boards. This is a common issue I am told due to chassis flex especially when riders stand up a lot. sled has over 17,000 miles and is an LTX GT 136 mono. FYI for cooler leaks!
Now get some tunnel stiffeners so that won't happen again.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
I am looking for some.... Steiner! I am going to add the rear idler wheel cross shaft and wheels instead of just those idlers attached to the side of the tunnel. Yamaha removed them on my 2010 probably for weight savings. I think that will help also!
HighSpeedLowDrag
The rear cross shaft will interfere with the rear swing arm. The older style swing arm which was used on the 136" models will cause interference with the rails on the 2010 and newer suspension which aren't milled down nearly as far as the old ones were. This would require removal of the idler wheels which just happen to be in the area of highest wear.
The 2010 Apex suspension without that cross shaft is the good one.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Really, wow wouldn't of thought of that????? Looks to be alot of room for movment ..... I will leave well enough alone Thanks HSLD!
- 146K
