Henny596
i am re-wiring a 2010 Nytro in which the fuel pump was deleted. I have a new fuel pump/sender in the tank and it has a 4 tab female connector. I have located the power wire and have verified that when I turn the key on it cycles on and then off as it should for priming the system.
My question is; is there actually 4 wires that go to the tank or just the power and a ground? Does anyone know which wires go where in the plug? I’m assuming 2 tabs are just dead?
Thanks in advance!
Thanks in advance!
