New slider or a slider kit, will quiet down your clutch again. There is o-rings in behind the sliders and they have likely collapsed slightly giving more clearance causing the noise. You will need the clutch break down tools to take apart the primary to change them. If you sent the clutch here, I could rebuild those for about $30 total.
