YamahaNytro30
- Mar 31, 2014
- 2010 Yamaha Nytro Xtx
I was wondering what was the tallest riser you can put on a 2010 Nytro XTX with needing more wiring
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
2.5-3" with out cables
Sent from my SCH-R530X using Tapatalk
YamahaNytro30
- Mar 31, 2014
What cables would you need if you go higher?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Mtx gas and break
YamahaNytro30
- Mar 31, 2014
Same for xtx?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
What do you meanSame for xtx?
YamahaNytro30
- Mar 31, 2014
Do you have to add break and throttle cables on the xtx with a 4" or higher riser? Or is that just on the MTX?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
You have to use the MTX cables on a XTX and a short track sleds
Arctic blonde rider
- Nov 8, 2013
- Whitehorse, Yukon
- 2010 XTX
2.5 x 146 Camoplast Peak track
Excell header
Fuel contol module
K&N air filters
Better board running boards
8" powderhound skis
Has anyone used the Powermadd throttle extension kits? I am looking to use a 6"-8" riser as well. And would three? Throttle, brake, and park brake?
Dr. FeeLGooD
I think alot of guys would just remove the park brake rather than extend the cable. But I have a 2" riser and an oft relocate with stock cables. If I went any taller I would consider a taller seat also.
Arctic blonde rider
- Nov 8, 2013
- Whitehorse, Yukon
- 2010 XTX
Excell header
Fuel contol module
K&N air filters
8" powderhound skis
Thanks Dr.
