APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
I was out driving my Apex yesterday and the headlight just went out on me. My "BLUE" High beam light is on when the lights are out and when I press the high/low button, it doesn't change. They finally came back on as I was driving so I just left them on low beam and I got back home and they were working when I shut the sled off. I started it this morning and same issue, "BLUE" high beam light on but no lights. It's just random when they go out. Tailight and cluster lights all work, just no headlights. They are factory lights, I replaced them 2 years ago with PIAA anti vibration bulbs. Any ideas would be great!
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Bad ground or connection somewhere. Start tracing the wiring and flexing the connections.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Thanks! I wll see what I can find.
Do you have HID or factory lights?
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Factory lights. I should have mentioned it in my post.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Headlights energized by a relay in footwell. Maybe start there.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Ok great. That will be where I start. Thanks!
Its the only relay with 5 wires on it.
check the fuse by the chain case as well. might have some corrosion there to.
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
Would anyone happen to have a wiring diagram for a 2011 Apex?
pdiddy
- Oct 12, 2004
- Southern Maine
PM me.Would anyone happen to have a wiring diagram for a 2011 Apex?
APEXRICH
- Apr 5, 2016
- NOVA SCOTIA
- 2006 APEX RTX
2011 APEX XTX
I just wanted to let everyone know the issue I came across when I got into my light issue. It was the 6 pin light connection, which you have to unplug to take light cluster off. It was the the ground wire(BLACK) connection. It had burnt at some point and there was a bad connection. I fixed it up and it worked for the 3 days I drove last weekend. Thanks for all the help!
pdiddy
- Oct 12, 2004
- Southern Maine
Great news!
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
Awesome post! And thank you for the follow up... my 2013 is doing exactly the same thing. Will check it out today
chris189
- Nov 27, 2011
- Hanover Ontario
Just to follow up, this was exactly the problem on my 2013. Ground block burnt, cut and soldered together.
Unsure how to post a picture.
Thanks again
Thanks again
