Hey guys,
Just installed the 2 speed setup in the apex that I bought from heelclicker and just wanted to discuss results so far. I found that with the setup that had been recommended with the white spring, 1 bolt in the shoulder and the center, that the sled kept reving above peak rpm. So I added 1 washer to the shoulder and my peak rpm is correct now although when you pin it, It is not climbing in rpm, it over revs and then comes back to peak. What factory yamaha springs have you guys been using in the 2 speed to bring down engagement? I think it will help fix the over rev, issue. Thanks guys.
