stanleypriddle
- Dec 26, 2016
- postville, nl
- 2011 RS Venture
Machine is getting gas and spark but not starting. We changed to a brand new set the other day and she started. Now my young nephew went out applied the choke and no start should the machine be so hard on plugs.?!?!
Sent from my HS_9DTB39 using Tapatalk
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
They can be know for this start cranking the motor and then start adding choke until it fires.
stanleypriddle
- Dec 26, 2016
- postville, nl
- 2011 RS Venture
I crank with choked use backed fired and flames came out the rear pipes. Took the plugs out there set with gas she wants to fire up but just won't got a new set of plugs otw to my town I leave in a remote community so it's hard to get the CR8E plugs
check the oil. might have gas in it as well witch will re-flood the plugs when trying to start.
