I put ST on my 07 Attak and REALLY like them. I will be going to an 11 xtx. My question is can I pull the ST from the 07 and put them on the 11. It looks like the part #s vary slightly but the holes appear to line up. The dual runners on the XTX are fine but the STs gave me such confidence I don't want to ride without them. I can't imagine ST and powersteering. Thanks in advance.
Different ski will need a different carbide. The ski bolt mounting position is different between the 07 and 11.
That's kind of what I thought. I will probably run what is on there next year then get a set of ST. Can't say I am happy......but thank you.Different ski will need a different carbide. The ski bolt mounting position is different between the 07 and 11.
unclearpine
On the ST site they say not to interchange from one sled to another sled. Each sled wears different and could be unpredictable results.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Switch the Ski's if your old ski's are good.
2010 & earlier Apex Ski's with Aggressive Snowtrackers work the best on 2011 and newer Apex's in my & some others who have tried both opinions.
That is what I run.
If you are going to run the 2011 & newer ski's I'd suggest buying the Semi's.
That is what I run.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
LOVE my ‘11 XTX with older style skis and aggressive trackers.
