2012 FX Nytro XTX Back Country
Srxspec
Ulmer Racing
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Took a 2012 FX Nytro XTX and put a Back Country 1-3/4" track, taller handlebar riser, water temp gauge, exhaust turn out, Excell header, Skinz Float Plate, etc on it. The only thing left to do is install some better skis!
Handlebar riser (took a stock Apex bar riser and cut it down so it added 2" of height from the stock XTX height).
Back Country Track installed (removing the upper tunnel protectors is a breeze, the front heat exchanger ones are a little more interesting)!
Skinz Float Plate and some overall pictures of the sled!
Water Temp Gauge installed.
Yamaha should take note of this. It seems like most of the things you did yamaha could add to the sled in stock form without raising the price much. they could also say the have the only sled with a temp gauge, instead of just an overheating light.
It looks really good. Why don't you bring it with you on one of TY Rides Allan ? Write it off as a business trip......LOL... ;)!
No other plans for it besides a different set of skis yet. No boost on it. bottlerocket, did you get the package you were looking at getting last spring?
