Kine
- Nov 21, 2022
- Rossland
- 2008 Yamaha Nytro MTX
2016 Yamaha Viper MTX
Hi everyone, new to the forum and the sport!
I recently got myself a 2008 Nytro MTX 162 and I am in the process of learning how to ride and also how to work on my sled.
The current track on it is pretty shot so I picked up a used Powerclaw track. Anyway, got the whole thing ripped apart only to discover that the set of drivers I picked up to go with the new track must have been off a newer Nytro as the axle shaft is about 5/8 longer then the drivers that came off with the old track. Anyone got any experience with this? Can I cut the newer style driveshaft off to fit in the chain case?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Does your mtx have reverse? The non reverse models had a shorter driveshaft.
Kine
- Nov 21, 2022
- Rossland
Yes, it does have reverse. It came with aftermarket drivers (white ones) and a 163x16 track with a 2.86 pitch. The "new" drivers I have are 3 inch pitch and looks to be the 2012 version. Is it possible to use this longer axle with my current chain case and setup or would I need to add spacers or cut the shaft down?
Just get the different end piece as it is different as well. If you use the 2012 end piece along with the 2012 shaft you have it will all work. Don't cut the shaft. Get the bolt also.
Number 72 in this picture.
www.cyclepartsnation.com
2012 Yamaha FX NYTRO RTX (FX10RTRBB) Track Drive 2 | CyclePartsNation
Shop online for OEM Track Drive 2 parts that fit your 2012 Yamaha FX NYTRO RTX (FX10RTRBB), search all our OEM Parts or call at 269-385-1540
